Hearing the Maximum Entropy Potential of a spike-generating Markov process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Rodrigo Cofre
  • Fonction : Auteur
  • PersonId : 943307
Bruno Cessac
We consider a spike-generating stationary Markov process whose transition probabilities are known. We show that there is a canonical potential whose Gibbs distribution, obtained from the Maximum Entropy Principle (MaxEnt), is the equilibrium distribution of this process. We provide a method to compute explicitly and exactly this potential as a linear combination of spatio-temporal interactions. The method is based on the Hammersley Clifford decomposition and on periodic orbits sampling. As an application, we establish an explicit correspondence between the parameters of the Ising model and the parameters of Markovian models like the Generalized-Linear Model.
prl_resub.pdf (102.28 Ko) Télécharger le fichier
hal-00861397 , version 1 (12-09-2013)
hal-00861397 , version 2 (20-09-2013)
hal-00861397 , version 3 (06-01-2014)
hal-00861397 , version 4 (14-05-2014)
  • HAL Id : hal-00861397 , version 1
Rodrigo Cofre, Bruno Cessac. Hearing the Maximum Entropy Potential of a spike-generating Markov process. 2013. ⟨hal-00861397v1⟩
575 Consultations
544 Téléchargements
