New interface
Reports (Technical report)
An Addendum to Rational Function Fitting
Laurent Belcour 1, 2, 3 Oliver Salazar-Celis 4 Romain Pacanowski 3, 2, *
* Corresponding author
2 MANAO - Melting the frontiers between Light, Shape and Matter
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, LP2N - Laboratoire Photonique, Numérique et Nanosciences
Abstract : In the paper Rational BRDF [PSCS∗12] Pacanowski et al. introduced a new algorithm to fit BRDF data. The fitting algorithm is an extension of the Rational Vertical Segment Interpolation method introduced by Salazar Celis et al. [SCV07]. In this document we clarify some technical and numerical aspects of the fitting procedure that need to be taken into account in order to get satisfactory fitting results.
Document type :
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-00913516
Contributor : Romain Pacanowski Connect in order to contact the contributor
Submitted on : Monday, September 22, 2014 - 2:08:02 PM
Last modification on : Wednesday, October 26, 2022 - 8:13:50 AM
Long-term archiving on: : Friday, April 14, 2017 - 12:22:27 PM
File
addendum.pdf
Identifiers
  • HAL Id : hal-00913516, version 2
Collections
Citation
Laurent Belcour, Oliver Salazar-Celis, Romain Pacanowski. An Addendum to Rational Function Fitting. [Technical Report] p. 2013. ⟨hal-00913516v2⟩
Share
Metrics
Record views
564
Files downloads
640
