The dual arc inclusion with differential inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2013
This paper continues our study of the minimum time problem with dynamics driven by a particular type of differential inclusion. We prove under certain assumptions that the dual arc associated to an optimal solution and the supergradient of the value function along the solution are intertwined in this new setting. We also derive new optimality conditions that contain nonsmooth features with an additional constancy condition on the Hamiltonian.
hal-00916116 , version 1 (09-12-2013)
Piermarco Cannarsa, Francesco Marino, Peter Wolenski. The dual arc inclusion with differential inclusions. Nonlinear Analysis: Theory, Methods and Applications, 2013, 79, pp.176-189. ⟨10.1016/j.na.2012.11.021⟩. ⟨hal-00916116⟩
Collections
SADCO TDS-MACS
86 Consultations
0 Téléchargements
