Mathematical and Numerical Analysis of some fluid-structure interaction problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
In this chapter we deal with some specific existence and numerical results applied to a 2D/1D fluid-structure coupled model, for an incompressible fluid and a thin elastic structure. We will try to underline some of the mathematical and numeri- cal difficulties that one may face when studying this kind of problems such as the geometrical nonlinearities or the added mass effect. In particular we will try to underline the link between the strategies of proof of weak or strong solutions and the possible algorithms to discretize these type of coupled problems
Fichier non déposé
hal-00917363 , version 1 (11-12-2013)
  • HAL Id : hal-00917363 , version 1
Céline Grandmont, Sárka Necasová, Maria Lukacova-Medvid'Ova. Mathematical and Numerical Analysis of some fluid-structure interaction problems. Bodnár, Tomáš and Galdi, Giovanni P. and Nečasová, Šárka. Fluid-Structure interaction and biomedical applications, Springer, 2014, Advances in Mathematical Fluid Mechanics, 978-3-0348-0821-7. ⟨hal-00917363⟩
367 Consultations
0 Téléchargements
