RIEMANNIAN METRICS ON 2D-MANIFOLDS RELATED TO THE EULER-POINSOT RIGID BODY MOTION. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
The Euler-Poinsot rigid body motion is a standard mechanical system and is a model for left-invariant Riemannian metric on SO(3). In this article using the Serret-Andoyer variables we parameterize the solutions and compute the Jacobi fields in relation with the conjugate locus evaluation. Moreover the metric can be restricted to a 2D-surface and the conjugate points of this metric are evaluated using recent work on surfaces of revolution. Another related 2D-metric on S2 associated to the dynamics of spin particles with Ising coupling is analysed using both geometric techniques and numerical simulations.
2013-CDC2-cots-submitted.pdf (1.09 Mo) Télécharger le fichier
hal-00918587 , version 1 (13-12-2013)
hal-00918587 , version 2 (14-01-2014)
  • HAL Id : hal-00918587 , version 1
Bernard Bonnard, Olivier Cots, Nataliya Shcherbakova. RIEMANNIAN METRICS ON 2D-MANIFOLDS RELATED TO THE EULER-POINSOT RIGID BODY MOTION.. 2013. ⟨hal-00918587v1⟩
458 Consultations
377 Téléchargements
