Algorithm Portfolios for Noisy Optimization: Compare Solvers Early
Noisy optimization is the optimization of objective functions corrupted by noise. A portfolio of algorithms is a set of algorithms equipped with an algorithm selection tool for distributing the compu- tational power among them. We study portfolios of noisy optimization solvers, show that different settings lead to dramatically different perfor- mances, obtain mathematically proved adaptivity by an ad hoc selection algorithm dedicated to noisy optimization. A somehow surprising result is that it is better to compare solvers with some lag; i.e., recommend the current recommendation of the best solver, selected from a comparison based on their recommendations earlier in the run.
