Convergence of a nonlinear entropy diminishing Control Volume Finite Element scheme for solving anisotropic degenerate parabolic equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2015
In this paper, we propose and analyze a Control Volume Finite Elements (CVFE) scheme for solving possibly degenerated parabolic equations. This scheme does not require the introduction of the so-called Kirchhoff transform in its definition. We prove that the discrete solution obtained \emph{via} the scheme remains in the physical range, and that the natural entropy of the problem decreases with time. The convergence of the method is proved as the discretization steps tend to $0$. Finally, numerical examples illustrate the efficiency of the method.
CVFE-NL_HAL.pdf (486.03 Ko) Télécharger le fichier
hal-00955091 , version 1 (03-03-2014)
Clément Cancès, Cindy Guichard. Convergence of a nonlinear entropy diminishing Control Volume Finite Element scheme for solving anisotropic degenerate parabolic equations. Mathematics of Computation, 2015, 85 (298), pp.549-580. ⟨10.1090/mcom/2997⟩. ⟨hal-00955091⟩
589 Consultations
764 Téléchargements
