Journal articles
Infinite horizon problems on stratifiable state-constraints sets
Cristopher Hermosilla 1, 2 Hasnaa Zidani 1, 2
1 Commands - Control, Optimization, Models, Methods and Applications for Nonlinear Dynamical Systems
CMAP - Centre de Mathématiques Appliquées - Ecole Polytechnique, Inria Saclay - Ile de France
Abstract : This paper deals with a state-constrained control problem. It is well known that, unless some compatibility condition between constraints and dynamics holds, the value function has not enough regularity, or can fail to be the unique constrained viscosity solution of a Hamilton-Jacobi-Bellman (HJB) equation. Here, we consider the case of a set of constraints having a stratified structure. Under this circumstance, the interior of this set may be empty or disconnected, and the admissible trajectories may have the only option to stay on the boundary without possible approximation in the interior of the constraints. In such situations, the classical pointing qualification hypothesis are not relevant. The discontinuous value function is then characterized by means of a system of HJB equations on each stratum that composes the state constraints. This result is obtained under a local controllability assumption which is required only on the strata where some chattering phenomena could occur.
Document type :
Journal articles
Complete list of metadata
Cited literature [39 references]  Display  Hide  Download
https://hal.inria.fr/hal-00955921
Contributor : Cristopher Hermosilla Connect in order to contact the contributor
Submitted on : Wednesday, July 2, 2014 - 10:58:29 AM
Last modification on : Friday, December 3, 2021 - 11:34:09 AM
Long-term archiving on: : Thursday, October 2, 2014 - 11:27:17 AM
File
Infinite_Horizon_Problems_on_S...
Identifiers
Citation
Cristopher Hermosilla, Hasnaa Zidani. Infinite horizon problems on stratifiable state-constraints sets. Journal of Differential Equations, Elsevier, 2015, 258 (4), pp.1430-1460. ⟨10.1016/j.jde.2014.11.001⟩. ⟨hal-00955921v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
