The Optimal Lower Bound for Generators of Invariant Rings without Finite SAGBI Bases with Respect to Any Admissible Order - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1999
We prove the existence of an invariant ring \textbfC[X_1,...,X_n]^T generated by elements with a total degree of at most 2, which has no finite SAGBI basis with respect to any admissible order. Therefore, 2 is the optimal lower bound for the total degree of generators of invariant rings with such a property.
dm030203.pdf (80.53 Ko) Télécharger le fichier
hal-00958927 , version 1 (13-03-2014)
Manfred Göbel. The Optimal Lower Bound for Generators of Invariant Rings without Finite SAGBI Bases with Respect to Any Admissible Order. Discrete Mathematics and Theoretical Computer Science, 1999, Vol. 3 no. 2 (2), pp.65-70. ⟨10.46298/dmtcs.259⟩. ⟨hal-00958927⟩
Collections
TDS-MACS
35 Consultations
712 Téléchargements
