Classes of graphs with restricted interval models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1999
We introduce q-proper interval graphs as interval graphs with interval models in which no interval is properly contained in more than q other intervals, and also provide a forbidden induced subgraph characterization of this class of graphs. We initiate a graph-theoretic study of subgraphs of q-proper interval graphs with maximum clique size k+1 and give an equivalent characterization of these graphs by restricted path-decomposition. By allowing the parameter q to vary from 0 to k, we obtain a nested hierarchy of graph families, from graphs of bandwidth at most k to graphs of pathwidth at most k. Allowing both parameters to vary, we have an infinite lattice of graph classes ordered by containment.
dm030404.pdf (123.08 Ko) Télécharger le fichier
hal-00958935 , version 1 (13-03-2014)
Andrzej Proskurowski, Jan Arne Telle. Classes of graphs with restricted interval models. Discrete Mathematics and Theoretical Computer Science, 1999, Vol. 3 no. 4 (4), pp.167-176. ⟨10.46298/dmtcs.263⟩. ⟨hal-00958935⟩
Collections
TDS-MACS
32 Consultations
890 Téléchargements
