Permutations avoiding an increasing number of length-increasing forbidden subsequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2000
A permutation π is said to be τ -avoiding if it does not contain any subsequence having all the same pairwise comparisons as τ . This paper concerns the characterization and enumeration of permutations which avoid a set F^j of subsequences increasing both in number and in length at the same time. Let F^j be the set of subsequences of the form σ (j+1)(j+2), σ being any permutation on \1,...,j\. For j=1 the only subsequence in F^1 is 123 and the 123-avoiding permutations are enumerated by the Catalan numbers; for j=2 the subsequences in F^2 are 1234 2134 and the (1234,2134)avoiding permutations are enumerated by the Schröder numbers; for each other value of j greater than 2 the subsequences in F^j are j! and their length is (j+2) the permutations avoiding these j! subsequences are enumerated by a number sequence \a_n\ such that C_n ≤ a_n ≤ n!, C_n being the nth Catalan number. For each j we determine the generating function of permutations avoiding the subsequences in F^j according to the length, to the number of left minima and of non-inversions.
dm040103.pdf (195 Ko) Télécharger le fichier
hal-00958943 , version 1 (13-03-2014)
Elena Barcucci, Alberto del Lungo, Elisa Pergola, Renzo Pinzani. Permutations avoiding an increasing number of length-increasing forbidden subsequences. Discrete Mathematics and Theoretical Computer Science, 2000, Vol. 4 no. 1 (1), pp.31-44. ⟨10.46298/dmtcs.273⟩. ⟨hal-00958943⟩
Collections
TDS-MACS
292 Consultations
899 Téléchargements
