Minimum survivable graphs with bounded distance increase - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2003
We study in graphs properties related to fault-tolerance in case a node fails. A graph G is k-self-repairing, where k is a non-negative integer, if after the removal of any vertex no distance in the surviving graph increases by more than k. In the design of interconnection networks such graphs guarantee good fault-tolerance properties. We give upper and lower bounds on the minimum number of edges of a k-self-repairing graph for prescribed k and n, where n is the order of the graph. We prove that the problem of finding, in a k-self-repairing graph, a spanning k-self-repairing subgraph of minimum size is NP-Hard.
dm060110.pdf (90.55 Ko) Télécharger le fichier
hal-00958995 , version 1 (13-03-2014)
Selma Djelloul, Mekkia Kouider. Minimum survivable graphs with bounded distance increase. Discrete Mathematics and Theoretical Computer Science, 2003, Vol. 6 no. 1 (1), pp.123-132. ⟨10.46298/dmtcs.338⟩. ⟨hal-00958995⟩
120 Consultations
819 Téléchargements
