Reports
Design and Analysis of Distributed Averaging with Quantized Communication
Abstract : Consider a network whose nodes have some initial values, and it is desired to design an algorithm that builds on neighbor to neighbor interactions with the ultimate goal of convergence to the average of all initial node values or to some value close to that average. Such an algorithm is called generically "distributed averaging," and our goal in this paper is to study the performance of a subclass of deterministic distributed averaging algorithms where the information exchange between neighboring nodes (agents) is subject to uniform quantization. With such quantization, convergence to the precise average cannot be achieved in general, but the convergence would be to some value close to it, called quantized consensus. Using Lyapunov stability analysis, we characterize the convergence properties of the resulting nonlinear quantized system. We show that in finite time and depending on initial conditions, the algorithm will either cause all agents to reach a quantized consensus where the consensus value is the largest quantized value not greater than the average of their initial values, or will lead all variables to cycle in a small neighborhood around the average. In the latter case, we identify tight bounds for the size of the neighborhood and we further show that the error can be made arbitrarily small by adjusting the algorithm's parameters in a distributed manner.
Document type :
Reports
Complete list of metadata
Cited literature [40 references]  Display  Hide  Download
https://hal.inria.fr/hal-00960891
Contributor : Mahmoud El Chamie Connect in order to contact the contributor
Submitted on : Saturday, September 13, 2014 - 10:10:57 PM
Last modification on : Thursday, January 20, 2022 - 5:29:07 PM
Long-term archiving on: : Sunday, December 14, 2014 - 10:25:06 AM
RR-8501.pdf
Identifiers
  • HAL Id : hal-00960891, version 2
  • ARXIV : 1403.4696
Collections
Citation
Mahmoud El Chamie, Ji Liu, Tamer Başar. Design and Analysis of Distributed Averaging with Quantized Communication. [Research Report] RR-8501, Inria. 2014, pp.33. ⟨hal-00960891v2⟩
Share
Metrics
Record views
146
Files downloads
215
