A Comparison of Geometric and Energy-Based Point Cloud Semantic Segmentation Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The recent availability of inexpensive RGB-D cameras, such as the Microsoft Kinect, has raised interest in the robotics community for point cloud segmentation. We are interested in the semantic segmentation task in which the goal is to find some relevant classes for navigation, wall, ground, objects, etc. Several effective solutions have been proposed, mainly based on the recursive decomposition of the point cloud into planes. We compare such a solution to a non-associative MRF method inspired by some recent work in computer vision. The MRF yields interesting results that are however less good than those of a carefully tuned geometric method. Nevertheless, MRF still has some advantages and we suggest some improvements.
IROS2013.pdf (277.83 Ko) Télécharger le fichier
poster.pdf (1.22 Mo) Télécharger le fichier
Format : Autre
hal-00963863 , version 1 (22-03-2014)
Mathieu Dubois, Paola K. Rozo, Alexander Gepperth, Fabio A. González O., David Filliat. A Comparison of Geometric and Energy-Based Point Cloud Semantic Segmentation Methods. 6th European Conference on Mobile Robotics (ECMR), IEEE, Sep 2013, Barcelona, Spain. pp.88-93, ⟨10.1109/ECMR.2013.6698825⟩. ⟨hal-00963863⟩
329 Consultations
563 Téléchargements
