On the absence of trapped modes in locally perturbed open waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Applied Mathematics Année : 2014
This paper presents a new approach for proving that the presence of a bounded defect in a uniform open waveguide cannot produce trapped modes, contrary to the case of a closed waveguide. The originality of the proof lies in the fact that it relies on a modal decomposition. It shows in particular that the absence of trapped modes results from a strong connection between the various modal components of the field. The case of the three-dimensional scalar wave equation is considered.
trapped-HAL.pdf (192.37 Ko) Télécharger le fichier
hal-00967920 , version 1 (31-03-2014)
Christophe Hazard. On the absence of trapped modes in locally perturbed open waveguides. IMA Journal of Applied Mathematics, 2014, pp.14. ⟨10.1093/imamat/hxu046⟩. ⟨hal-00967920⟩
270 Consultations
546 Téléchargements
