A determinant of Stirling cycle numbers counts unlabeled acyclic single-source automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
We show that a determinant of Stirling cycle numbers counts unlabeled acyclic single-source automata. The proof involves a bijection from these automata to certain marked lattice paths and a sign-reversing involution to evaluate the determinant. We also give a formula for the number of acyclic automata with a given set of sources.
657-3327-2-PB.pdf (103.88 Ko) Télécharger le fichier
hal-00972318 , version 1 (03-04-2014)
David Callan. A determinant of Stirling cycle numbers counts unlabeled acyclic single-source automata. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 2 (2), pp.77--86. ⟨10.46298/dmtcs.421⟩. ⟨hal-00972318⟩
Collections
TDS-MACS
64 Consultations
881 Téléchargements
