Progress on the traceability conjecture for oriented graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2008
A digraph is k-traceable if each of its induced subdigraphs of order k is traceable. The Traceability Conjecture is that for k ≥ 2 every k-traceable oriented graph of order at least 2k − 1 is traceable. The conjecture has been proved for k ≤ 5. We prove that it also holds for k = 6.
965-3520-1-PB.pdf (124.79 Ko) Télécharger le fichier
hal-00972339 , version 1 (03-04-2014)
Marietjie Frick, Peter Katrenič. Progress on the traceability conjecture for oriented graphs. Discrete Mathematics and Theoretical Computer Science, 2008, Vol. 10 no. 3 (3), pp.105--113. ⟨10.46298/dmtcs.428⟩. ⟨hal-00972339⟩
Collections
TDS-MACS
59 Consultations
852 Téléchargements
