Supervisory Control of Air-Fuel Ratio in Spark Ignition Engines
The problem of air-fuel ratio stabilization in spark ignition engines is addressed in this paper. The proposed strategy consists of proper switching among two control laws to improve quality of the closed-loop system. The first control law is based on an a priori off-line identified engine model and ensures robust and reliable stabilization of the system at large, while the second control law is adaptive, it provides on-line adaptive adjustment to the current fluctuations and improves accuracy of the closed-loop system. The supervisor realizes a switching rule between these control laws providing better performance of regulation. Results of implementation on two vehicles are reported and discussed.
