Mu-synthesis with dynamic D-Scalings using Quantum Particle Swarm Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes to revisit the μ-synthesis problem with a recent and efficient meta-heuristic called Quantum Particle Swarm Optimization (QPSO). This algorithm allows optimizing dynamic (or static) D-scalings without fitting them, which leads to robust performance controllers. This method has been applied successfully to a classical flexible plant control problem with a reasonable computation time.
Fichier non déposé
hal-00975142 , version 1 (08-04-2014)
Philippe Feyel, Gilles Duc, Guillaume Sandou. Mu-synthesis with dynamic D-Scalings using Quantum Particle Swarm Optimization. 13th European Control Conference (ECC 2014), Jun 2014, Strasbourg, France. pp.606 - 611, ⟨10.1109/ECC.2014.6862395⟩. ⟨hal-00975142⟩
178 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
