Semi-Lagrangian simulations on polar grids: from diocotron instability to ITG turbulence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
While developing a new semi-Lagrangian solver, the gap between a linear Landau run in 1D 1D and a 5D gyrokinetic simulation in toroidal geometry is quite huge. Intermediate test cases are welcome for checking the code.We consider here as building block, a 2D guiding center type equation on an annulus.We rst revisit a 2D test case previously done with a PIC approach [15] and detail the boundary conditions. We then consider a 4D drift kinetic slab simulation for which we give some rst results of a new conservative method.
vlasovia-diocons.pdf (515.72 Ko) Télécharger le fichier
hal-00977342 , version 1 (11-04-2014)
hal-00977342 , version 2 (15-12-2014)
  • HAL Id : hal-00977342 , version 1
Nicolas Crouseilles, Pierre Glanc, Sever Adrian Hirstoaga, Eric Madaule, Michel Mehrenberger, et al.. Semi-Lagrangian simulations on polar grids: from diocotron instability to ITG turbulence. 2014. ⟨hal-00977342v1⟩
775 Consultations
404 Téléchargements
