Optimal Values of Multidimensional Mean-Payoff Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
In this paper, we study the set of thresholds that the protag- onist can force in a zero-sum two-player multidimensional mean-payoff game. The set of maximal elements of such a set is classically called the Pareto curve, a classical tool to analyze trade-offs. Indeed, as weights are given as vectors in multiple dimensions, there can be incomparable such thresholds, and even an infinite number of incomparable ones. Our main results are as follow. First, we study the geometry of this set and show that it can be effectively represented as a finite union of convex sets. Second, we study the computational complexity of natural associated de- cision problems. In particular, we show that the we can decide in Σ 2 -P if this set intersects a convex set of points defined by linear inequations. We also show that this problem is both NP-hard and coNP-hard. Third, we show that the Pareto curve can be approximated in polynomial time for fixed number of dimensions and unary encoding of weights.
main-long.pdf (489.27 Ko) Télécharger le fichier
main.pdf (281.22 Ko) Télécharger le fichier
hal-00977352 , version 1 (11-04-2014)
hal-00977352 , version 2 (13-04-2014)
hal-00977352 , version 3 (29-04-2014)
hal-00977352 , version 4 (18-10-2014)
hal-00977352 , version 5 (08-02-2015)
hal-00977352 , version 6 (22-05-2015)
  • HAL Id : hal-00977352 , version 4
Romain Brenguier, Jean-François Raskin. Optimal Values of Multidimensional Mean-Payoff Games. [Research Report] Universit ́e Libre de Bruxelles (U.L.B.), Belgium. 2014. ⟨hal-00977352v4⟩
308 Consultations
384 Téléchargements
