Optimal Values of Multidimensional Mean-Payoff Games - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
In this paper, we study the set of thresholds that the protagonist can force in a zero-sum two-player multidimensional mean-payoff game. The set of maximal elements of such a set is called the Pareto curve, a classical tool to analyze trade-offs. As thresholds are vectors of real numbers in multiple dimensions, there exist usually an infinite number of such maximal elements. Our main results are as follow. First, we study the geometry of this set and show that it is definable as a finite union of convex sets given by linear inequations. Second, we provide a Σ2 P algorithm to decide if this set intersects a convex set defined by linear inequations, and we prove the optimality of our algorithm by providing a matching complexity lower bound for the problem. Furthermore, we show that, under natural assumptions, i.e. fixed number of dimensions and polynomially bounded weights in the game, the problem can be solved in deterministic polynomial time. Finally, we show that the Pareto curve can be effectively constructed, and under the former natural assumptions, this construction can be done in deterministic polynomial time.
cav15-long.pdf (520.21 Ko) Télécharger le fichier
hal-00977352 , version 1 (11-04-2014)
hal-00977352 , version 2 (13-04-2014)
hal-00977352 , version 3 (29-04-2014)
hal-00977352 , version 4 (18-10-2014)
hal-00977352 , version 5 (08-02-2015)
hal-00977352 , version 6 (22-05-2015)
  • HAL Id : hal-00977352 , version 6
Romain Brenguier, Jean-François Raskin. Optimal Values of Multidimensional Mean-Payoff Games. [Research Report] Université Libre de Bruxelles (U.L.B.), Belgium. 2014. ⟨hal-00977352v6⟩
Collections
LARA
306 Consultations
381 Téléchargements
