On the chromatic number of some flip graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2009
This paper studies the chromatic number of the following four flip graphs (under suitable definitions of a flip): the flip graph of perfect matchings of a complete graph of even order, the flip graph of triangulations of a convex polygon (the associahedron), the flip graph of non-crossing Hamiltonian paths of a set of points in convex position, and the flip graph of triangles in a convex point set. We give tight bounds for the latter two cases and upper bounds for the first two.
1026-4303-1-PB.pdf (189.34 Ko) Télécharger le fichier
hal-00988210 , version 1 (07-05-2014)
Ruy Fabila-Monroy, David Flores-Peñaloza, Clemens Huemer, Ferran Hurtado, Jorge Urrutia, et al.. On the chromatic number of some flip graphs. Discrete Mathematics and Theoretical Computer Science, 2009, Vol. 11 no. 2 (2), pp.47--56. ⟨10.46298/dmtcs.460⟩. ⟨hal-00988210⟩
Collections
TDS-MACS
186 Consultations
1098 Téléchargements
