The b-chromatic number of powers of cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2013
A b-coloring of a graph G by k colors is a proper vertex coloring such that each color class contains a color-dominating vertex, that is, a vertex having neighbors in all other k-1 color classes. The b-chromatic number χb(G) is the maximum integer k for which G has a b-coloring by k colors. Let Cnr be the rth power of a cycle of order n. In 2003, Effantin and Kheddouci established the b-chromatic number χb(Cnr) for all values of n and r, except for 2r+3≤n≤3r. For the missing cases they presented the lower bound L:= min n-r-1,r+1+⌊ n-r-1 / 3⌋ and conjectured that χb(Cnr)=L. In this paper, we determine the exact value on χb(Cnr) for the missing cases. It turns out that χb(Cnr)>L for 2r+3≤n≤2r+3+r-6 / 4.
1856-7797-1-PB.pdf (357.85 Ko) Télécharger le fichier
hal-00990613 , version 1 (13-05-2014)
Anja Kohl. The b-chromatic number of powers of cycles. Discrete Mathematics and Theoretical Computer Science, 2013, Vol. 15 no. 1 (1), pp.147--156. ⟨10.46298/dmtcs.631⟩. ⟨hal-00990613⟩
Collections
TDS-MACS
64 Consultations
876 Téléchargements
