An algorithm for the principal ideal problem in indefinite quaternion algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Deciding whether an ideal of a number field is principal and finding a generator is a fundamental problem with many applications in computational number theory. For indefinite quaternion algebras, the decision problem reduces to that in the underlying number field. Finding a generator is hard, and we present a heuristically subexponential algorithm.
pip.pdf (294.75 Ko) Télécharger le fichier
hal-00996346 , version 1 (26-05-2014)
Aurel Page. An algorithm for the principal ideal problem in indefinite quaternion algebras. Algorithmic Number Theory Symposium ANTS XI, Aug 2014, GyeongJu, South Korea. pp.366-384, ⟨10.1112/S1461157014000321⟩. ⟨hal-00996346⟩
174 Consultations
456 Téléchargements
