SUPERDIFFUSION OF ENERGY IN A CHAIN OF HARMONIC OSCILLATORS WITH NOISE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Physics Année : 2015
We consider a one dimensional infinite chain of harmonic oscillators whose dynamics is perturbed by a stochastic term conserving energy and momentum. We prove that in the unpinned case the macroscopic evolution of the energy converges to the solution of the fractional diffusion equation ∂ t u = −|∆| 3/4 u. For a pinned system we prove that its energy evolves diffusively, generalizing some results of [4].
jkosuper-final-s.pdf (501.72 Ko) Télécharger le fichier
hal-00997642 , version 1 (28-05-2014)
hal-00997642 , version 2 (23-02-2015)
hal-00997642 , version 3 (20-06-2015)
Paternité - Pas d'utilisation commerciale
Milton Jara, Tomasz Komorowski, Stefano Olla. SUPERDIFFUSION OF ENERGY IN A CHAIN OF HARMONIC OSCILLATORS WITH NOISE. Communications in Mathematical Physics, 2015, 339, pp.46. ⟨10.1007/s00220-015-2417-6⟩. ⟨hal-00997642v3⟩
666 Consultations
192 Téléchargements
