Design of impulsive adaptive observers for improvement of persistency of excitation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Adaptive Control and Signal Processing Année : 2014
The development of adaptive observer techniques for nonlinear systems in the output canonical form is proposed applying additional impulsive feedback in the observer equations. The stability of new impulsive adaptive observer is investigated. It is shown that under some conditions the proposed impulsive feedback can improve the rate of the observer convergence or relax the requirement on persistency of excitation, which is usually introduced to ensure convergence of the parameter estimates. The proposed feasibility conditions include positivity of dwell time (boundedness of impulse frequency) and solvability of some Lyapunov-like matrix inequalities. The results are illustrated by simulation for three examples (including a single link flexible joint robot example).
Impulsive_adaptive_observer.pdf (414.35 Ko) Télécharger le fichier
hal-01016332 , version 1 (30-06-2014)
Denis Efimov, Alexander Fradkov. Design of impulsive adaptive observers for improvement of persistency of excitation. International Journal of Adaptive Control and Signal Processing, 2014, pp.1--18. ⟨10.1002/acs.2506⟩. ⟨hal-01016332⟩
223 Consultations
248 Téléchargements
