Robust control system for Spacecraft Motion Trajectory - Archive ouverte HAL Access content directly
Journal Articles European Journal of Pure and Applied Mathematics Year : 2014
In aerospace field the economic realization of a spacecraft is one of the main objectives which should be accomplished by conceiving the optimal propulsion system and best control programs. This article focuses on the implementation of uncertain control system theory and development of a robust control system of Spacecraft Motion Trajectory (SMT). The proposed strategy involves the nonlinear mathematical model of SMT expressed in the central field, which is linearized by the Taylor expansion, and model reference Adaptive Control Approach (ACA) with the second Lyapunov method to offer a high rate and unfailing performance in the functioning. The efficiencies of the linearization procedure and the control approach are theoretically investigated through some realistic simulations and tests under Matlab.
Not file
Dates and versions
hal-01017472 , version 1 (02-07-2014)
Identifiers
  • HAL Id : hal-01017472 , version 1
Cite
Zarina Samigulina, Olga Shiryayeva, Galina Samigulina, Hassen Fourati. Robust control system for Spacecraft Motion Trajectory. European Journal of Pure and Applied Mathematics, 2014, 7 (3), pp.289-303. ⟨hal-01017472⟩
199 View
0 Download
Share
