A Framework for Enhancing Responsiveness in Sales Order Processing System Using Web Services and Ubiquitous Computing Technologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study attempts to enhance the responsiveness of enterprises by adjusting the delivery dates taking into account of the production and delivery schedules in a supply chain. To enhance responsiveness, we suggest a due-date assignment method and re-negotiation process for a sales order processing system. The due-date assignment method is designed with the concept of categorized customers' priorities and the re-negotiation process is designed with the concept of the partial delivery and due-date delay allowances. Usually, the due-dates have been considered as customer-assigned exogenous parameters or fixed endogenous variables set by manufacturers. However, those are customary in some industries, e.g. semi-conductor manufacturing, that customers often request changes for their delivery dates after placing an order if something unexpected happens. From these observations, we also propose a new architecture of responsive sales order processing system based on Web Services and Ubiquitous Computing technologies for reliable real-time information.
03380441.pdf (366.77 Ko) Télécharger le fichier
hal-01055823 , version 1 (13-08-2014)
Paternité
Mokmin Park, Kitae Shin, Hanil Jeong, Jinwoo Park. A Framework for Enhancing Responsiveness in Sales Order Processing System Using Web Services and Ubiquitous Computing Technologies. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.449-456, ⟨10.1007/978-3-642-16358-6_56⟩. ⟨hal-01055823⟩
60 Consultations
209 Téléchargements
