Robust finite-time output feedback stabilization of the double integrator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2014
Denis Efimov
Emmanuel Moulay
SIC
The problem of finite-time output stabilization of the double integrator is addressed applying the homogeneity approach. A homogeneous controller and a homogeneous observer are designed (for different degrees of homogeneity) ensuring the finite-time stabilization. Their combination under mild conditions is shown to stay homogeneous and finite-time stable as well. Robustness and effects of discretization on the obtained closed loop system are analyzed. The efficiency of the obtained solution is demonstrated in computer simulations.
Automatique
Double_integrator_journal.pdf (305.57 Ko) Télécharger le fichier
hal-01056207 , version 1 (18-08-2014)
Emmanuel Bernuau, Wilfrid Perruquetti, Denis Efimov, Emmanuel Moulay. Robust finite-time output feedback stabilization of the double integrator. International Journal of Control, 2014, 88 (3), pp.451-460. ⟨10.1080/00207179.2014.956340⟩. ⟨hal-01056207⟩
323 Consultations
783 Téléchargements
