A Cancellation Operator Suitable for Identification of Nonlinear Volterra Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Céline Casenave
Gérard Montseny
  • Fonction : Auteur
  • PersonId : 942369
We present a new identification method for nonlinear possibly singular Volterra models based on a suitable operatorial transformation of the problem with the property that some nonlinear terms are cancelled, allowing to get an equivalent formulation well adapted to least square identification.
Casenave_et_Montseny_-_A_Cancellation_Operator_Suitable_for_Identificatio.pdf (194.75 Ko) Télécharger le fichier
hal-01061526 , version 1 (07-09-2014)
  • HAL Id : hal-01061526 , version 1
Céline Casenave, Gérard Montseny. A Cancellation Operator Suitable for Identification of Nonlinear Volterra Models. IFAC Workshop on Control of Distributed Parameter Systems, CDPS 2009, Jul 2009, Toulouse, France. ⟨hal-01061526⟩
87 Consultations
54 Téléchargements
