Optimal identification of delay-diffusive operators and application to the acoustic impedance of absorbent materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Céline Casenave
Gérard Montseny
  • Fonction : Auteur
  • PersonId : 942369
We present an original method devoted to the optimal identification of a wide class of complex linear operators involving some delay components, based on suitable infinitedimensional state formulations of diffusive type. Thanks to the intrinsic properties of these state formulations, cheap and precise numerical approximations are straightforwardly obtained, leading to approximate quadratic problems of reasonable dimension. We then propose this method for identification of the acoustic impedance of absorbent materials designed for noise reduction of aircraft motors
Casenave_et_Montseny_-_2009_-_Optimal_identification_of_delay-diffusive_operator.pdf (159.37 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01061527 , version 1 (07-09-2014)
  • HAL Id : hal-01061527 , version 1
Céline Casenave, Gérard Montseny. Optimal identification of delay-diffusive operators and application to the acoustic impedance of absorbent materials. 7th IFAC Worshop on Time delay Systems (IFAC TDS 2007), Sep 2007, Nantes, France. ⟨hal-01061527⟩
271 Consultations
108 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
