Control of a Multi-Stage Continuous Fermentor for the study of the wine fermentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yeasts play a central role in the wine making process. To study the yeasts in a stable environment and physiological state, a Multi-Stage Continuous Fermentor (MSCF) has been designed that mimics steps of the batch fermentation process. In this paper, the problem of the control of the sugar concentrations in each of the four reactors of the MSCF is considered. The cascade structure of the device leads to a constraint on the input flow rates (the control variables). A control strategy based on a linearizing control law coupled with a state observer and an anti windup component is proposed and finally implemented on the experimental process.
Preprint_Casenave_et_al._-_2014_-_Control_of_a_Multi-Stage_Continuous_Fermentor_for_.pdf (409.51 Ko) Télécharger le fichier
hal-01064704 , version 1 (17-09-2014)
Céline Casenave, Denis Dochain, Jérôme Harmand, Marc Perez, Alain Rapaport, et al.. Control of a Multi-Stage Continuous Fermentor for the study of the wine fermentation. 19th IFAC World Congress 2014, Aug 2014, Cap Town, South Africa. ⟨10.3182/20140824-6-ZA-1003.00627⟩. ⟨hal-01064704⟩
299 Consultations
746 Téléchargements
