On asymptotic exit-time control problems lacking coercivity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Control, Optimisation and Calculus of Variations Année : 2014
The research on a class of asymptotic exit-time problems with a vanishing Lagrangian, begun in [M. Motta and C. Sartori, Nonlinear Differ. Equ. Appl. Springer (2014).] for the compact control case, is extended here to the case of unbounded controls and data, including both coercive and non-coercive problems. We give sufficient conditions to have a well-posed notion of generalized control problem and obtain regularity, characterization and approximation results for the value function of the problem.
hal-01068349 , version 1 (25-09-2014)
Monica Motta, Caterina Sartori. On asymptotic exit-time control problems lacking coercivity. ESAIM: Control, Optimisation and Calculus of Variations, 2014, 20 (4), pp.957-982. ⟨10.1051/cocv/2014003⟩. ⟨hal-01068349⟩
Collections
SADCO TDS-MACS
39 Consultations
0 Téléchargements
