Hierarchical DAG Scheduling for Hybrid Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Accelerator-enhanced computing platforms have drawn a lot of attention due to their massive peak com-putational capacity. Despite significant advances in the pro-gramming interfaces to such hybrid architectures, traditional programming paradigms struggle mapping the resulting multi-dimensional heterogeneity and the expression of algorithm parallelism, resulting in sub-optimal effective performance. Task-based programming paradigms have the capability to alleviate some of the programming challenges on distributed hybrid many-core architectures. In this paper we take this concept a step further by showing that the potential of task-based programming paradigms can be greatly increased with minimal modification of the underlying runtime combined with the right algorithmic changes. We propose two novel recursive algorithmic variants for one-sided factorizations and describe the changes to the PaRSEC task-scheduling runtime to build a framework where the task granularity is dynamically adjusted to adapt the degree of available parallelism and kernel effi-ciency according to runtime conditions. Based on an extensive set of results we show that, with one-sided factorizations, i.e. Cholesky and QR, a carefully written algorithm, supported by an adaptive tasks-based runtime, is capable of reaching a degree of performance and scalability never achieved before in distributed hybrid environments.
recursive.pdf (633.47 Ko) Télécharger le fichier
hal-01078359 , version 1 (16-12-2014)
  • HAL Id : hal-01078359 , version 1
Wei Wu, Aurelien Bouteiller, George Bosilca, Mathieu Faverge, Jack Dongarra. Hierarchical DAG Scheduling for Hybrid Distributed Systems. IEEE International Parallel & Distributed Processing Symposium (IPDPS 2015), May 2015, Hyderabad, India. ⟨hal-01078359⟩
366 Consultations
774 Téléchargements
