The complexity of finding arc-disjoint branching flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
The concept of arc-disjoint flows in networks was recently introduced in \cite{bangTCSflow}. This is a very general framework within which many well-known and important problems can be formulated. In particular, the existence of arc-disjoint branching flows, that is, flows which send one unit of flow from a given source $s$ to all other vertices, generalizes the concept of arc-disjoint out-branchings (spanning out-trees) in a digraph. A pair of out-branchings $B_{s,1}^+,B_{s,2}^+$ from a root $s$ in a digraph $D=(V,A)$ on $n$ vertices corresponds to arc-disjoint branching flows $x_1,x_2$ (the arcs carrying flow in $x_i$ are those used in $B_{s,i}^+$, $i=1,2$) in the network that we obtain from $D$ by giving all arcs capacity $n-1$.It is then a natural question to ask how much we can lower the capacities on the arcs and still have, say, two arc-disjoint branching flows from the given root $s$.We prove that for every fixed integer $k \geq 2$ it is\begin{itemize}\item an NP-complete problem to decide whether a network ${\cal N}=(V,A,u)$ where $u_{ij}=k$ for every arc $ij$ has two arc-disjoint branching flows rooted at $s$.\item a polynomial problem to decide whether a network ${\cal N}=(V,A,u)$ on $n$ vertices and $u_{ij}=n-k$ for every arc $ij$ has two arc-disjoint branching flows rooted at $s$.\end{itemize}The algorithm for the later result generalizes the polynomial algorithm, due to Lov\'asz, for deciding whether a given input digraph has two arc-disjoint out-branchings rooted at a given vertex.Finally we prove that under the so-called Exponential Time Hypothesis (ETH), for every $\epsilon{}>0$ and for every $k(n)$ with $(\log{}(n))^{1+\epsilon}\leq k(n)\leq \frac{n}{2}$ (and for every large $i$ we have $k(n)=i$ for some $n$) there is no polynomial algorithm for deciding whether a given digraph contains twoarc-disjoint branching flows from the same root so that no arc carries flow larger than $n-k(n)$.
RR-8640.pdf (815.95 Ko) Télécharger le fichier
hal-01088664 , version 1 (28-11-2014)
  • HAL Id : hal-01088664 , version 1
Jørgen Bang-Jensen, Frédéric Havet, Anders Yeo. The complexity of finding arc-disjoint branching flows. [Research Report] RR-8640, INRIA Sophia Antipolis; INRIA. 2014. ⟨hal-01088664⟩
241 Consultations
168 Téléchargements
