New interface
Journal articles
Gyroaverage operator for a polar mesh
Christophe Steiner 1, * Michel Mehrenberger 2, 1, 3 Nicolas Crouseilles 4 Virginie Grandgirard 5 Guillaume Latu 5 Fabien Rozar 6, 7, 5
* Corresponding author
2 TONUS - TOkamaks and NUmerical Simulations
IRMA - Institut de Recherche Mathématique Avancée, Inria Nancy - Grand Est
4 IPSO - Invariant Preserving SOlvers
IRMAR - Institut de Recherche Mathématique de Rennes, Inria Rennes – Bretagne Atlantique
7 HiePACS - High-End Parallel Algorithms for Challenging Numerical Simulations
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest
Abstract : In this work, we are concerned with numerical approximation of the gyroaverage operators arising in plasma physics to take into account the effects of the finite Larmor radius corrections. The work initiated in [5] is extended here to polar geometries. A direct method is proposed in the space configuration which consists in integrating on the gyrocircles using interpolation operator (Hermite or cubic splines). Numerical comparisons with a standard method based on a Padé approximation are performed: (i) with analytical solutions, (ii) considering the 4D drift-kinetic model with one Larmor radius and (iii) on the classical linear DIII-D benchmark case [6]. In particular, we show that in the context of a drift-kinetic simulation, the proposed method has similar computational cost as the standard method and its precision is independent of the radius. PACS. PACS-key discribing text of that key – PACS-key discribing text of that key
Document type :
Journal articles
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01090681
Contributor : Nicolas Crouseilles Connect in order to contact the contributor
Submitted on : Monday, December 8, 2014 - 6:08:21 PM
Last modification on : Tuesday, June 14, 2022 - 8:25:05 AM
Long-term archiving on: : Monday, March 9, 2015 - 10:10:31 AM
File
gyromoyenne_vlasovia13.pdf
Identifiers
Citation
Christophe Steiner, Michel Mehrenberger, Nicolas Crouseilles, Virginie Grandgirard, Guillaume Latu, et al.. Gyroaverage operator for a polar mesh. The European Physical Journal D : Atomic, molecular, optical and plasma physics, 2015, 69 (1), pp.221. ⟨10.1140/epjd/e2014-50211-7⟩. ⟨hal-01090681⟩
Share
Metrics
Record views
650
Files downloads
290
