Gyroaverage operator for a polar mesh - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The European Physical Journal D : Atomic, molecular, optical and plasma physics Année : 2015
In this work, we are concerned with numerical approximation of the gyroaverage operators arising in plasma physics to take into account the effects of the finite Larmor radius corrections. The work initiated in [5] is extended here to polar geometries. A direct method is proposed in the space configuration which consists in integrating on the gyrocircles using interpolation operator (Hermite or cubic splines). Numerical comparisons with a standard method based on a Padé approximation are performed: (i) with analytical solutions, (ii) considering the 4D drift-kinetic model with one Larmor radius and (iii) on the classical linear DIII-D benchmark case [6]. In particular, we show that in the context of a drift-kinetic simulation, the proposed method has similar computational cost as the standard method and its precision is independent of the radius. PACS. PACS-key discribing text of that key – PACS-key discribing text of that key
gyromoyenne_vlasovia13.pdf (2.33 Mo) Télécharger le fichier
hal-01090681 , version 1 (08-12-2014)
Christophe Steiner, Michel Mehrenberger, Nicolas Crouseilles, Virginie Grandgirard, Guillaume Latu, et al.. Gyroaverage operator for a polar mesh. The European Physical Journal D : Atomic, molecular, optical and plasma physics, 2015, 69 (1), pp.221. ⟨10.1140/epjd/e2014-50211-7⟩. ⟨hal-01090681⟩
667 Consultations
324 Téléchargements
