Design of orbitally stable zero dynamics for a class of nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2004
A method for the generation of globally attractive limit cycles for nonlinear systems is presented. It consists in designing an output that, when regulated through a suitable feedback, forces a limit cycle in the zero dynamics. Conditions are then given to ensure that a globally attractive limit cycle in the zero dynamics results in a globally attractive limit cycle in the whole system. The method is illustrated on the torque control of an induction motor.
scl02def.pdf (620.75 Ko) Télécharger le fichier
hal-01091542 , version 1 (05-12-2014)
Frédéric Grognard, Carlos Canudas de Wit. Design of orbitally stable zero dynamics for a class of nonlinear systems. Systems and Control Letters, 2004, 51 (2), pp.89-103. ⟨10.1016/S0167-6911(03)00209-3⟩. ⟨hal-01091542⟩
217 Consultations
152 Téléchargements
