Adding a single memory per agent gives the fastest average consensus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Alain Sarlette
Previous papers have proposed to add memory registers to the individual dynamics of discrete-time linear agents to move faster towards average consensus under interactions dictated by a given but unknown graph. They have proved that adding one memory slot per agent allows faster convergence. We here prove that this situation cannot be improved by adding more memory slots. We conclude by discussing a more general framework for our result in an algorithmic context.
1412.0402v1.pdf (138.81 Ko) Télécharger le fichier
hal-01093907 , version 1 (05-01-2015)
hal-01093907 , version 2 (28-12-2015)
Alain Sarlette. Adding a single memory per agent gives the fastest average consensus. 2014. ⟨hal-01093907v1⟩
210 Consultations
338 Téléchargements
