Integral Control on Lie Groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2015
Alain Sarlette
  • Fonction : Auteur
  • PersonId : 10453
  • IdHAL : asarlet
In this paper, we extend the popular integral control technique to systems evolving on Lie groups. More explicitly, we provide an alternative definition of ‘‘integral action’’ for proportional(–derivative)-controlled systems whose configuration evolves on a nonlinear space, where configuration errors cannot be simply added up to compute a definite integral. We then prove that the proposed integral control allows to cancel the drift induced by a constant bias in both first order (velocity) and second order (torque) control inputs for fully actuated systems evolving on abstract Lie groups. We illustrate the approach by 3-dimensional motion control applications.
zzs_scl2015.pdf (519.5 Ko) Télécharger le fichier
hal-01093913 , version 1 (05-01-2015)
hal-01093913 , version 2 (28-12-2015)
Zhifei Zhang, Alain Sarlette, Zhihao Ling. Integral Control on Lie Groups. Systems and Control Letters, 2015, 80, pp.9-15. ⟨hal-01093913v2⟩
317 Consultations
348 Téléchargements
