High Level Transforms for SIMD and Low-Level Computer Vision Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a review of algorithmic transforms called High Level Transforms for IBM, Intel and ARM SIMD multi-core pro-cessors to accelerate the implementation of low level image pro-cessing algorithms. We show that these optimizations provide a significant acceleration. A first evaluation of 512-bit SIMD Xeon-Phi is also presented. We focus on the point that the combination of optimizations leading to the best execution time cannot be pre-dicted, and thus, systematic benchmarking is mandatory. Once the best configuration is found for each architecture, a comparison of these performances is presented. The Harris points detection opera-tor is selected as being representative of low level image processing and computer vision algorithms. Being composed of five convolu-tions, it is more complex than a simple filter and enables more op-portunities to combine optimizations. The presented work can scale across a wide range of codes using 2D stencils and convolutions.
simd-140122.pdf (1.01 Mo) Télécharger le fichier
hal-01094906 , version 1 (06-01-2015)
Lionel Lacassagne, Daniel Etiemble, Hassan Zahraee, Alain Dominguez, Pascal Vezolle. High Level Transforms for SIMD and Low-Level Computer Vision Algorithms. Symposium on Principles and Practice of Parallel Programming / WPMVP, Feb 2014, Orlando, Florida, United States. pp.8, ⟨10.1145/2568058.2568067⟩. ⟨hal-01094906⟩
685 Consultations
1176 Téléchargements
