A smoothing approach for composite conditional gradient with nonsmooth loss - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We consider learning problems where the non-smoothness lies both in the convex empirical risk and in the regularization penalty. Examples of such problems include learning with nonsmooth loss functions and atomic decomposition regularization penalty. Such doubly nonsmooth learning problems prevent the use of recently proposed composite conditional gradient algorithms for training, which are particularly attractive for large-scale applications. Indeed, they rely on the assumption that the empirical risk part of the objective is smooth. We propose a composite conditional gradient algorithm with smoothing to tackle such learning problems. We set up a framework allowing to systematically design parametrized smooth surrogates of nonsmooth loss functions. We then propose a smoothed composite conditional gradient algorithm, for which we prove theoretical guarantees on the accuracy. We present promising experimental results on collaborative filtering tasks.
RR-8662.pdf (881.38 Ko) Télécharger le fichier
hal-01096630 , version 1 (15-01-2015)
  • HAL Id : hal-01096630 , version 1
Federico Pierucci, Zaid Harchaoui, Jérôme Malick. A smoothing approach for composite conditional gradient with nonsmooth loss. [Research Report] RR-8662, INRIA Grenoble. 2014. ⟨hal-01096630⟩
700 Consultations
518 Téléchargements
