Effective thermal conductivity of a wet porous medium – Presence of hysteresis when modeling the spatial water distribution for the pendular regime. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This paper deals with the heat transfer between two spherical grains separated by a small gap; dry air is located around the grains and a liquid water meniscus is supposed to be present between them. This problem can be seen as a micro-scale cell of an assembly of solid grains, for which we are looking for the effective thermal conductivity. For a fixed contact angle and according to the volume of the liquid meniscus, two different shapes are possible for the meniscus, giving a “contacting” state (when the liquid makes a true bridge between the two spheres) and a “non-contacting” one (when the liquid is split in two different drops, separated by a thin air layer); the transition between these two states occurs at different times when increasing or decreasing the liquid volume, thus leading to a hysteresis behavior when computing the thermal flux across the domain.
Fichier non déposé
hal-01096806 , version 1 (18-12-2014)
  • HAL Id : hal-01096806 , version 1
Édouard Canot, Renaud Delannay, Salwa Mansour, Mohamad Muhieddine, Ramiro Javier March. Effective thermal conductivity of a wet porous medium – Presence of hysteresis when modeling the spatial water distribution for the pendular regime.. [Research Report] INRIA Rennes - Bretagne Atlantique. 2014, pp.8. ⟨hal-01096806⟩
358 Consultations
0 Téléchargements
