Stability and feasibility of state-constrained linear MPC without stabilizing terminal constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is concerned with stability and recur-sive feasibility of constrained linear receding horizon control schemes without terminal constraints and costs. Particular attention is paid to characterize the basin of attraction S of the asymptotically stable equilibrium. For stabilizable linear systems with quadratic costs and convex constraints we show that any compact subset of the interior of the viability kernel is contained in S for sufficiently large optimization horizon N . An analysis at the boundary of the viability kernel provides a connection between the growth of the infinite horizon optimal value function and stationarity of the feasible sets. Several examples are provided which illustrate the results obtained.
mtns2014.pdf (388.33 Ko) Télécharger le fichier
hal-01098279 , version 1 (23-12-2014)
  • HAL Id : hal-01098279 , version 1
Andrea Boccia, Lars Grüne, Karl Worthmann. Stability and feasibility of state-constrained linear MPC without stabilizing terminal constraints . MTNS 2014, 2014, Los Angeles, United States. pp.453-460. ⟨hal-01098279⟩
239 Consultations
237 Téléchargements
