Asymptotic stability and transient optimality of economic MPC without terminal conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Process Control Année : 2014
We consider an economic nonlinear model predictive control scheme without terminal constraints or costs. We give conditions based on dissipativity and con-trollability properties under which the closed loop is practically asymptotically stable. Under the same conditions we prove approximate transient optimality of the closed loop on finite time intervals. Two numerical examples illustrate our theoretical findings.
empc_stability_revision.pdf (491 Ko) Télécharger le fichier
hal-01101238 , version 1 (08-01-2015)
Lars Grüne, Marleen Stieler. Asymptotic stability and transient optimality of economic MPC without terminal conditions. Journal of Process Control, 2014, 24 (8), pp.1187 - 1196. ⟨10.1016/j.jprocont.2014.05.003⟩. ⟨hal-01101238⟩
Collections
SADCO TDS-MACS
74 Consultations
382 Téléchargements
