Experimental validation of a sampled-data passivity-based controller for coordination of converters in a fuel cell system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Industrial Electronics Année : 2015
This paper deals with the control of a hybrid source combining a proton exchange membrane fuel cell and supercapacitors. To achieve this objective, an interconnection and damping assignment passivity-based control (IDA-PBC) in a sampled-data context is implemented. This paper first details this new controller and shows that it ensures the stabilization of the hybrid system at its desired equilibrium point under large range of sampling periods. These considerations are followed by a detailed discussion on experimental results achieved on a 1.2 kW test bench.
Hilairet2015.pdf (352.92 Ko) Télécharger le fichier
hal-01101293 , version 1 (18-05-2022)
Paternité - Pas d'utilisation commerciale
Mickael Hilairet, Olivier Bethoux, Malek Ghanes, Valentin Tanasa, Jean-Pierre Barbot, et al.. Experimental validation of a sampled-data passivity-based controller for coordination of converters in a fuel cell system. IEEE Transactions on Industrial Electronics, 2015, 62 (8), pp.5187-5194. ⟨10.1109/TIE.2014.2362497⟩. ⟨hal-01101293⟩
449 Consultations
67 Téléchargements
