Hausdorff volume in non equiregular sub-Riemannian manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2015
Frédéric Jean
In this paper we study the Hausdorff volume in a non equiregular sub-Riemannian manifold and we compare it with a smooth volume. We first give the Lebesgue decomposition of the Hausdorff volume. Then we study the regular part, show that it is not commensurable with the smooth volume, and give conditions under which it is a Radon measure. We finally give a complete characterization of the singular part. We illustrate our results and techniques on numerous examples and cases (e.g. to generic sub-Riemannian structures).
volumes_V11.pdf (269.18 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01107470 , version 1 (21-01-2015)
hal-01107470 , version 2 (27-06-2015)
Roberta Ghezzi, Frédéric Jean. Hausdorff volume in non equiregular sub-Riemannian manifolds. Nonlinear Analysis: Theory, Methods and Applications, 2015, 126, pp.345-377. ⟨10.1016/j.na.2015.06.011⟩. ⟨hal-01107470v2⟩
293 Consultations
185 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
