Fast integer multiplication using generalized Fermat primes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
For almost 35 years, Schönhage-Strassen's algorithm has been the fastest algorithm known for multiplying integers, with a time complexity $O(n \cdot \log n \cdot \log \relax \log n)$ for multiplying $n$-bit inputs. In 2007, Fürer proved that there exists $K>1$ and an algorithm performing this operation in $O(n \cdot \log n \cdot K^{\log^* n})$. Recent work by Harvey, van der Hoeven, and Lecerf showed that this complexity estimate can be improved in order to get $K=8$, and conjecturally $K=4$. We obtain here the same result $K=4$ using simple modular arithmetic as a building block, and a careful complexity analysis. We obtain a similar result $K=4$ using an alternative somewhat simpler algorithm, which relies on arithmetic modulo generalized Fermat primes.
conjfim.pdf (450.93 Ko) Télécharger le fichier
hal-01108166 , version 1 (22-01-2015)
hal-01108166 , version 2 (28-01-2016)
hal-01108166 , version 3 (10-08-2017)
hal-01108166 , version 4 (13-04-2018)
Svyatoslav Covanov, Emmanuel Thomé. Fast integer multiplication using generalized Fermat primes. 2016. ⟨hal-01108166v2⟩
1132 Consultations
1407 Téléchargements
