A numerical approach for the Poisson equation in a planar domain with a small inclusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We consider the Poisson equation in a domain with a small hole of size δ. We present a simple numerical method, based on an asymptotic analysis, which allows to approximate robustly the far field of the solution as δ goes to zero without meshing the small hole. We prove the stability of the scheme and provide error estimates. We end the paper with numerical experiments illustrating the efficiency of the technique.
ChCl14.pdf (439.5 Ko) Télécharger le fichier
Orders.pdf (5.71 Ko) Télécharger le fichier
OrdersC3.pdf (5.75 Ko) Télécharger le fichier
Resultats1.pdf (6.99 Ko) Télécharger le fichier
Resultats2.pdf (7.02 Ko) Télécharger le fichier
Resultats3.pdf (7.01 Ko) Télécharger le fichier
Resultats4.pdf (7.01 Ko) Télécharger le fichier
Threshold.pdf (5.88 Ko) Télécharger le fichier
hal-01109552 , version 1 (26-01-2015)
hal-01109552 , version 2 (05-01-2016)
Lucas Chesnel, Xavier Claeys. A numerical approach for the Poisson equation in a planar domain with a small inclusion. 2014. ⟨hal-01109552v1⟩
Collections
ENSTA
622 Consultations
591 Téléchargements
